  • SN95 4.6L Mustang Tech
timing/distributor ?
  • Thread starter Thread starter batman96
  • Start date Start date Jun 5, 2008
batman96
  • Jun 5, 2008
i need to move me distributor for a little bit. now my dad said on his pinto with a mustang engine in it which he use to have he would adjust the timing by moving the distrubior like turning it left or right. now if i move mine will it do this?
BobHyatt
378
  • Jun 5, 2008
5.0/4cyl/6cyl? You can't just "move" the distributor. That affects the engine timing and it has to be set properly. I don't remember how the 5.0 drives the distributor, but if it uses a gear rather than the old Chrysler "flat tab driver" then you can remove the distributor and turn the whole thing a bit and put it back in, and that will let you move the outer case because you moved the rotor/shaft the same amount keeping the timing correct. You will need to set the timing after doing this however...
batman96
  • Jun 5, 2008
i have a 6er mine is a bigger rectagle. i just need to get to something right under the assibly.
BobHyatt
378
  • Jun 5, 2008
Is this a distributor or just a coil pack? Does it have a cap you can remove with a rotor inside? If not, you can put the coil pack wherever you want...
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jun 5, 2008
  • Jun 5, 2008
theres nothing to move. there is a synchronizer and camshaft position sensor where the distributor would be, but it is not adjustable.
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
