I recently converted an Autolite 2100 to an Edlebrock 1406 + Performer intake on a stock 289. I couldn’t get the timing correct initially because the idle was running too fast, even with the idle screw all the way out. But the car ran great. It was a lot more responsive than with the 2V. The tires even screeched a little when the auto trans shifted from first to second.
When I finally figured out why the idle was running too fast, corrected it and set the timing to 6 degrees (and also tried 12 degrees) BTDC, the car ran the same as with the 2V (which is what I originally expected). No more screeching tires. I believe that when the timing was incorrect, it was more retarded because the vacuum hose on the distributor was pointing more towards the left (8 o’clock). Or, I guess it could've been off by one tooth. Right now, it’s pointing almost straight (6 o’clock) towards the front of the car.
Does anyone know why the car ran better when the ignition timing was off ?
I’d like to get responsiveness back but am not sure what the timing was and if it was OK to run it that way.
What should I set the timing to for the best low end response?
I have a stock 289 (67 mustang, auto trans), a stock distributor with Petronix electronic points.
Any explanation and/or tips would be greatly appreciated.
