  • SN95 4.6L Mustang Tech
timing for vortech v-2
  • Thread starter Thread starter ooraceredgt
  • Start date Start date Dec 4, 2004
ooraceredgt
204
  • Dec 4, 2004
im getting detonation in my engine after 3000 rpm (usually when i get boost) under full throttle all the way to redline. i have my predator set at the following
WOT: richened
2k-4k -6
4k-7k -6
SPARK ADVANCE: retard
2k-4k -6
4k-7k -6
am i running to much fuel or do i need to advance the spark or what. im a little confuse about this stuff. any help would be great
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Dec 4, 2004
  • Dec 4, 2004
the Predator has been programmed for a blower car right? this isn't an off the shelf Predator i hope.
what octane is your fuel? it should be 92 or higher.
if you are getting detonation, you either don't have the right octane or you aren't getting enough fuel. or you have the timing advance too much.
ooraceredgt
204
  • Dec 4, 2004
yea the predator as far as i know has been programmed for s/c apllication and i am runnig 93 octane
DBMSTNG
2,120
not quite here
Dec 4, 2004
  • Dec 4, 2004
i'm not familiar with the Predator, but i'd think you need to change the richened number higher. try 0 and see if it helps. i'm guessing -6 leans it out and +6 will make it rich.
ooraceredgt
204
  • Dec 4, 2004
negative is richened.
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
Pinging Under Load - 96GT
  • 1slow4vgt
  • Jun 24, 2021
SN95 4.6L Mustang Tech Jun 24, 2021
1slow4vgt
