Timing Gear install question
Last5.0
404
I installed a Comp Cams double roller timing chain set, but when I torque the bolt down on the cam gear to spec the back of the gear rubs the cam retainer slightly (no end play). Is this ok?? The stock gear is shaped differently on the backside and actually has a ridge that buts up against the cam, not the retainer.
