  • 1994 - 1995 Specific Tech
Timing gear puller
  • Thread starter Thread starter CManT1914
  • Start date Start date Jun 24, 2005
CManT1914
3,172
Killeen, Texas
Jun 24, 2005
  • Jun 24, 2005
I'm trying to gather all the tools and miscellaneous parts I'm gonna need for my heads/cam swap. Which one of these gear pullers will work best for the timing chain?
5 ton two jaw
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00946905000
7 ton two jaw
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00946903000
5 ton three jaw
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00946906000
I found a balancer puller already, thanks!
scarless
175
  • Jun 24, 2005
You don't need a gear puller to take off the timing gears. It just slides off most of the time.
1slow95
1,797
ohio
Jun 24, 2005
  • Jun 24, 2005
The stock one should come right off without a puller. If you're degreeing the cam, you might need a puller to remove the aftermarket timing chain. The 3-prong will probably work the best.
Just FYI, you can rent those at auto zone or advance.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Jun 24, 2005
  • Jun 24, 2005
i never needed any sort of puller when removing either the stock or the aftermarket chain. the only puller you need is the one that removes the balancer.
CManT1914
3,172
Killeen, Texas
Jun 24, 2005
  • Jun 24, 2005
All right, thanks. I knew it wasn't neccesary, but I figured if it made it any easier I'd at least look into it. As long as any of these will work, then I'll keep them in mind in case I run into a bind. Thanks again.
-Chris
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
SN95 The Unicorn
  • HANO Motorsports
  • May 18, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
HANO Motorsports
