Timing gear puller
CManT1914
3,172
Killeen, Texas
I'm trying to gather all the tools and miscellaneous parts I'm gonna need for my heads/cam swap. Which one of these gear pullers will work best for the timing chain?
5 ton two jaw
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00946905000
7 ton two jaw
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00946903000
5 ton three jaw
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00946906000
I found a balancer puller already, thanks!
The stock one should come right off without a puller. If you're degreeing the cam, you might need a puller to remove the aftermarket timing chain. The 3-prong will probably work the best.
Just FYI, you can rent those at auto zone or advance.
All right, thanks. I knew it wasn't neccesary, but I figured if it made it any easier I'd at least look into it. As long as any of these will work, then I'll keep them in mind in case I run into a bind. Thanks again.
-Chris
