Timing gears anyone?
  • Thread starter Thread starter Boss 351
  • Start date Start date Nov 1, 2006
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Nov 1, 2006
  • Nov 1, 2006
I think I will use timing gears for the engine I'm building for myself. I'd like a timing belt but it's too expensive. I hear there's much deflection in timing chains once they reach 1000 miles. I don't mind the noise timing gears make so that's not a con for me (besides I think my exhaust is loud enough to hide the noise)
I'm just wondering who else is actually using this? I think you need to grind a little off the timing cover to make it work, is that true?
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Nov 1, 2006
  • Nov 1, 2006
I believe most are for non EFI cars. Something about the excess vibration transfered screws up electronics... But dont quote me.
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Nov 1, 2006
  • Nov 1, 2006
most people say not to run them because of harmonics that are transfered from the crankshaft to the camshaft that could possibly screw up bearings and whatnot. but if you dont care about the noise or anything else go for it. if they were bad for your motor they wouldnt make them
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Nov 1, 2006
  • Nov 1, 2006
I ran a set in a different car before.. They were LOUD, even the quiet sets are like a super charger. It'll make it hard to adjust your rockers...
They can lead to increased wear and tear after long periods of operation but hey we like to rebuild stuff.
seijirou
2,417
DFW
Nov 1, 2006
  • Nov 1, 2006
Some people install their cams a few degrees more advanced than they would otherwise to compensate for this deflection.
H
Aluminum timing chain guides ?
  • healy1963
  • May 5, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 5, 2026
healy1963
H
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
F
5R55S Torque Converter Grinding while seating
  • feloniusgru
  • Mar 2, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 2, 2026
ctandc
C
