Timing Help (347)
Currently have a freshly built SCAT 347 Stroker with GT40 3 bar heads, and an e303 cam. Car keeps wanting to stall and seems to be running super rich. What is a good spot to set the timing to? I’ve seen a couple of people
say 12 degrees BTDC but i’m not sure. Any help will be appreciated.
That should be fine. The general range for best performance is 10-14 degrees. Poor timing is not likely the reason the engine won't run.
Kurt
Please answer the spout and codes questions.
Reactions: General karthief
