  • 1994 - 1995 Specific Tech
timing her in
  • Thread starter Thread starter Dagz
  • Start date Start date May 15, 2006
Dagz
173
Quesnel Canada
May 15, 2006
  • May 15, 2006
well boys i decided to throw the light on the car to find out where i was. I disconnected the spout conector and found the caar was at 6*, which is kinda weak took a couple cranks to get her to fire. I advanced the timing to 12* ( I think that is 2* advanced correct me if i'm wrong ) And of coure the it started to ping. Took it back dropped it to 10*, still pings under load on hot days.
MAF is clean the only thing i have left to do is drop it to 8*
What do you think this is all on regular octane
Thanx Dagz
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
May 15, 2006
  • May 15, 2006
reset the ECU and try setting it again
HISSIN50
34
129
May 15, 2006
  • May 15, 2006
That is probably why it was set where it was. High heat and higher octane go hand in hand.
Dagz
173
Quesnel Canada
May 15, 2006
  • May 15, 2006
ya tried resetting the ECU but a no go, and six is just to retarted. Might be the heat and dense air here in BC i dunno anyone else, oh ya by the way is 10* stock?
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
May 15, 2006
  • May 15, 2006
I know how that goes. I checked mine today ... to find it was at 0*!
Pinging sux. Fortunately, I was able to set it at 12* (89 octane) and no pinging. If you do a search on here for "pinging", you will find that there have been issues with ping that were resolved several different ways. Maybe you'll get some ideas there. Personally, I believe we can thank FoMoCo for pinging because of their design on the combustion chambers.
slocomo
48
  • May 16, 2006
timing
I have mine set at 17 btcdegrees with the spout pulled. when I rechecked it after I put the spout back in it only showed 26 btc degrees I think total. I'm using 93 octane. No pinging. I tried to change it but the distributor was siezed.
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
J
Car Diagnosis
  • j.2016
  • Aug 31, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 31, 2025
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
