Timing Issue
  • Thread starter Thread starter redfox91
  • Start date Start date Jun 1, 2008
R
redfox91
94
Northwest Arkansas
Jun 1, 2008
  • Jun 1, 2008
Ok I have been having a problem with backfiring through the intake. So I have replaced the control module, distributor, plugs, wires, cap, and rotor. I have stabbed my distributor over and over. I set my timing to 13 and put the spout back in and it still hesitates and pops through the intake. Last night I decided to try something different so I pulled the spout connector out and locked timing in at 36*. Now it is running great??? I know this is not a good fix. I know there is a problem but I don't know how to fix it. Do any of you guys have any ideas?
wildstang90
87
Bristol, TN
Jun 2, 2008
  • Jun 2, 2008
Try cleaning your MAF and look at the voltage on the TPS should be 1vdc with the key on and the motor off.
R
redfox91
94
Northwest Arkansas
Jun 2, 2008
  • Jun 2, 2008
Those were among the first things I tried. The TPS checks out great and the Maf is really new but I cleaned it anyway. I think it has something to do with the timing or what controls the timing when the spout is plugged in.
bt15
129
Oahu
Jun 2, 2008
  • Jun 2, 2008
First, check your coil. Replace it with a known working coil from a buddy's car if you can to see it that's the fix. The next possibilities include jumped timing chain / gear, spun distributor gear, or simply an improperly indexed distributor.
R
redfox91
94
Northwest Arkansas
Jun 2, 2008
  • Jun 2, 2008
I have checked the timing gear and the chain because I just recently had to do an oil pump swap so I thought I would check the chain for slack. It all checked good. The distributor gear is good as I have just put a new distributor in. It is definately indexed correctly, TDC and rotor pointing in the correct direction...etc.
I also checked to make sure at TDC the HB is pointing directly at 0
R
redfox91
94
Northwest Arkansas
Jun 3, 2008
  • Jun 3, 2008
Only 2 responses with 74 views??? Come on fellas I need some help here.
F
FordGuy88
241
Park Ridge, IL
Jun 3, 2008
  • Jun 3, 2008
You check the whole valvetrain?
93 LX
3,081
Norwalk, CA.
Jun 3, 2008
  • Jun 3, 2008
Ill bet your balancer is bad making the ring move. This is what happened to my 86, replace it and set the timing at 10 now I do not have any issues.
R
redfox91
94
Northwest Arkansas
Jun 4, 2008
  • Jun 4, 2008
The valvetrain is good and the Harmonic Balancer is new. I checked the Balancer marks with TDC and it is dead on.
Brandon11010
71
#10
  • Jun 4, 2008
  • #10
Prob a dumb response but you sure you got your firing order correct?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jun 5, 2008
#11
  • Jun 5, 2008
  • #11
Usally a backfire through the intake is a timing/valve train issue. If a intake valve is not closing properly you could be back-firing through the intake. I would start with going over the valve train to make sure you don't have an issue there. Then I would start to play with the timing.
J
Jmood
169
Arkansaw
Jun 5, 2008
#12
  • Jun 5, 2008
  • #12
I would swap the distributor with your friends, if you have one....I had a similar problem a couple months ago, $10 distributor from ebay fixed it.
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
