Timing Issue
Ok I have been having a problem with backfiring through the intake. So I have replaced the control module, distributor, plugs, wires, cap, and rotor. I have stabbed my distributor over and over. I set my timing to 13 and put the spout back in and it still hesitates and pops through the intake. Last night I decided to try something different so I pulled the spout connector out and locked timing in at 36*. Now it is running great??? I know this is not a good fix. I know there is a problem but I don't know how to fix it. Do any of you guys have any ideas?
First, check your coil. Replace it with a known working coil from a buddy's car if you can to see it that's the fix. The next possibilities include jumped timing chain / gear, spun distributor gear, or simply an improperly indexed distributor.
I have checked the timing gear and the chain because I just recently had to do an oil pump swap so I thought I would check the chain for slack. It all checked good. The distributor gear is good as I have just put a new distributor in. It is definately indexed correctly, TDC and rotor pointing in the correct direction...etc.
I also checked to make sure at TDC the HB is pointing directly at 0
Usally a backfire through the intake is a timing/valve train issue. If a intake valve is not closing properly you could be back-firing through the intake. I would start with going over the valve train to make sure you don't have an issue there. Then I would start to play with the timing.
