This is starting to get annoying!
I just recently fixed a lifter tunnel gasket leak. The dumb F**k that I bought the car from used I swear, a whole tube of RTV and no front and rear rubber gaskets. There was oil basically streaming out of the rear part of the lower intake. So I replaced it and my DUMB A** forgot to put the car at TDC and mark the distributor. I can't seem to get the timing back to where it was. Its really close, but not quite there. I put #1 to TDC and made sure the rotor was lined up with the #1 plug. But my question is, where should the distributor rotation be when I line up the rotor with #1 plug? I guess what I mean, is where should the harness plug be in position to the rotor when I drop the dist. back down? Maybe I'm just dumb this time around. Its been a LONG week! Thanks guys!
