Timing issues
  • Thread starter Thread starter ColdAudio
  • Start date Start date Feb 15, 2006
C
ColdAudio
31
  • Feb 15, 2006
Hey guys, I'm trying to figure out what's up with my timing and I haven't got a clue. First off, when setting it (with the spout out), you use the solid piece of metal that comes out straight over the balancer, not the one with the circle, correct? I matched up about 10*-12* with the spout out, and when I put the spout back in, it only moved by about 1*. Isn't it supposed to be 10*-12* base, and at least 20* at idle? Mine at idle with the spout in is almost identical as with the spout out. Any ideas on what the problem may be? Thanks!
bcd
274
arab al
Feb 15, 2006
  • Feb 15, 2006
I'm not sure what its supposed to be at idle cause i currently have something screwed in mycomputer but i wouldn't think the timing should advance until you rev it. i could be wrong though. jrichker would know though
HISSIN50
34
129
Feb 15, 2006
  • Feb 15, 2006
I also use the straight edge (not the circle). SOmething is up with the SPOUT circuit. Dump the codes and see if you get one for it. As BCD said, you can see Jrichker's great write ups for how to find the short.
Good luck.
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Electrical Ecc overiding base timing?
  • Dontknowchit
  • Mar 18, 2024
2K
Fox 5.0 Mustang Tech Mar 24, 2024
TwoRockTwo
