Timing jumps when i put spout back in.HELP!
davins130
424
i got my car to start finally, had the spout out and set it at 10*.. Then as soon as i put the spout it the mark moves to the left of the marker about an inch. Is this normal and am i at 10* still? Any help would be appreciated because i need to drive this thing in a couple hours. THanks!
thanks alot, i wasnt expecting that to happen...BTW what does that spout do? it looks like it disconnects some circuit when you pull it out and completes it when its in.
lol, that would be a pretty accurate description :D. It's a jumper.
Basically, when you have it out, you can set your base timing. When you pop it back in, the computer will add timing on top of your base timing according to conditions.
