  • 1994 - 1995 Specific Tech
Timing Problem
  • Thread starter Thread starter stallion09
  • Start date Start date Nov 7, 2004
stallion09
  • Nov 7, 2004
I seem to have a problem whenever I try to advance my timing. I advanced
the timing to about 12 degrees by removing the spout connector and turning
the distributer cap until my light reads 12 degrees. I then reconnect the
spout and test drive the car. Well everything runs fine and dandy even under
full throttle bursts. Fast forward about a month and now when I give it
full throttle in 2nd or 3rd gear I get a pinging sound. This only occurs
under hard acceleration full throttle runs. THis was not happening when I
changed the timing. Everything is tight and I always use hi octane gas.
Any ideas?
94TURBO5 O
2,509
VA
Nov 7, 2004
  • Nov 7, 2004
It could be lots of things. Do a search on pinging and you'll get tons of hits.
stallion09
  • Nov 7, 2004
I will look, but I am wondering why it works for the first few weeks.
HISSIN50
34
129
Nov 7, 2004
  • Nov 7, 2004
how are ambient temps compared to before? how about your motor's running temps?
any codes? FP or O2's would be something to look for. you guys seem to get pinging issues with a dirty MAF wire - checked it lately? run an oiled gauze air filter?
i would back the timing down a smidge for now. could have been a bad batch of gas too.
there is a ton more, as JR said.
good luck.
HoofnIt
1,175
North Carolina
Nov 7, 2004
  • Nov 7, 2004
Mine still pings, even after adding my AFRs. I use 91 octane. If it is below 70 outside, the car will not ping. I can say that the pinging is better after adding the heads but it DID not go away. I'm hoping my dyno tune will find the problem and finally put this gremlin to rest.
gcomfx.com
3,690
Republic, MO
Nov 7, 2004
  • Nov 7, 2004
What do your plugs look like? What are they gapped at? Try gapping them less.... worked on my nitrous ping.
stallion09
  • Nov 11, 2004
Frustrating,
I just checked the timing and it was set lower then I remember it. I just reset it to
12 degrees. I will driver later.....
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
