Timing Problem
  • Thread starter Thread starter 1988WHTGT
  • Start date Start date Apr 4, 2009
1988WHTGT
270
Guyton, GA
Apr 4, 2009
  • Apr 4, 2009
I've been trying to figure out why my car has been running like crap. Went and checked the timing today. It was at 15 degrees (spout connector unplugged). When revving it, it just stays at 15 degrees and is not advancing. What could be wrong?
flyby84
48
Arkansas
Apr 5, 2009
  • Apr 5, 2009
vacuum advance gone bad??
dcurtis
688
Apr 5, 2009
  • Apr 5, 2009
Our cars don't have vacuum advance. Does it stay at 15 degrees timing with the spout in?
dcurtis
688
Apr 5, 2009
  • Apr 5, 2009
First make sure the spout is getting good connection, check the 2 wires for damage. Not sure if I read it right but one website said you can test the spout connector wires and it should equal battery voltage. It says to test from the wire to the distributor base if that matters? Engine running at idle.
93 LX
3,081
Norwalk, CA.
Apr 5, 2009
  • Apr 5, 2009
with the sprout out the static timing is set.. this does not advance with the connector out.
1988WHTGT
270
Guyton, GA
Apr 6, 2009
  • Apr 6, 2009
Spout connector was in and it wasn't advancing. Also notice another weird thing....it will sit and idle in neutral fine, then I push the clutch in and put it in in gear it revs up for a second and then idles a little higher than before. Do I just have all kinds of problems? ha
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 6, 2009
  • Apr 6, 2009
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
See the "Surging Idle Checklist for help with all your idle/stall problems. Everything you need to find and fix idle problems is in there.
The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
93 LX
3,081
Norwalk, CA.
Apr 7, 2009
  • Apr 7, 2009
I would check the the sprout to make sure it is a jumper it could be open which will not let the computer control the advance.
1988WHTGT
270
Guyton, GA
Apr 20, 2009
  • Apr 20, 2009
How would I do that?
1988WHTGT
270
Guyton, GA
Apr 20, 2009
#10
  • Apr 20, 2009
  • #10
Ok, I just tried this with a test light and jumper wire. The light on the test light is kind of dim with the key and gets bright with the key on but does not blink any. Do I have some major problems?
1988WHTGT
270
Guyton, GA
Apr 20, 2009
#11
  • Apr 20, 2009
  • #11
This thing still barely has any fuel pressure according to the gauge. I'm going to try a new fuel filter tomorrow and go from there =(
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
