timing question
Reinstall the spout connector and start the car up. With the timing light still hooked up and the spout connector connected, your timing should be moving around between 24-30 degrees, give or take a couple of degrees.
You should see an initial jump at warm idle of about 10-12* from simply installing the SPOUT connector. So if you set SPOUT out timing to 10*, look for the base timing with the connector installed to jump to around 20-22*.
Good luck.
