Timing Question
  • Thread starter Thread starter 885.0conv
  • Start date Start date Nov 5, 2008
885.0conv
238
Phoenix, Az
Nov 5, 2008
  • Nov 5, 2008
I just put my engine back together and will not turn over. I know that it is the timing. I was wondering what the proper way to set the distributor. I went to http://*******.com/index.php/topic,7114.0.html and followed the directions. I was confused about the point where it says to turn pulley to TDC and then it shows the timing line at 10 degrees. I was wondering do you match the timing line to 10 degrees BTDC and make sure that the rotor matches up with the first point on the cap. Thanks for any help.
885.0conv
238
Phoenix, Az
Nov 5, 2008
  • Nov 5, 2008
s b f t e c h for the *******
ID89GT
1,659
18
49
Spokane Valley, WA
Nov 6, 2008
  • Nov 6, 2008
It will not turn over or it will not start?
885.0conv
238
Phoenix, Az
Nov 6, 2008
  • Nov 6, 2008
It will crank like it wants to start but doesnt fire, it back-fired a couple of times which tells me at the timing is off
J
jsynhon
10
  • Nov 6, 2008
pull #1 plug out with distributor out. hold your finger over spark plug hole. rotate engine until air pushes from cylinder. you can usually see in the cylinder with a flashlight to see when up. align harmonic balancer to 0 degrees. you are now top dead center.drop the disributor back in and point the rotor button right at the #1 cylinder spark plug wire where it will sit on dist. cap. should fire right up.
885.0conv
238
Phoenix, Az
Nov 7, 2008
  • Nov 7, 2008
Thanks for the help jsynhon was able to get it started just have to get a 24 # maf. You can smell the extra gas coming out the exhaust.
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
CAMTWO1070
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
  • dan50
  • Jul 18, 2026
dan50
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
