Timing Questions
Georgie said:
Whats all this about advancing or retarding the timing..im pretty much stock, how much power can i get out of it , is it worth it? how complicated with the right tools??
I used to have a whole book of dyno tests on 5.0's. They claimed bumping the timing from 10* (stock) to 14* was worth 5-7hp.
It is not complicated, all you need is a timing light and a 1/2" wrench.
Whether or not it's worth it is a judgment call. If you bump the timing up, you will have to run premium gas. If you're not already running premium, that means an extra $3 or so every time you fill the tank. With gas prices how they are, I recently set the timing back to stock on one of my 5.0's. If you already run premium, do it, it's free power.
Also, have you removed your air silencer yet? It's the goofy plastic deal bolted to the air box behind the fender. The same dyno test book said removing that is worth about 5hp too, it will just make your intake sound a bit louder.
Jeff
If you have to go to a higher grade of fuel to accomodate a timing bump, lower the timing back down.
There are a couple articles on setting the timing out there if you search.
Good luck.
