timing spout voltage
roworld
105
baltimore md
I've been having a problem with my car staying running with the timing spout connected. With the spout disconnected the car runs fine. I know the spout is like a splice connecting the computer to the distributer for timming advance. I just got done checking the wire between pin 36 to the spout & the spout to the distributer connecter it checks ok, no short or open wire. With spout removed I read 7.27v on one side & 5.88v on the other. Is this ok I was surprised to have voltage on both sides.
Timing problems where the car runs better with the SPOUT out fall into 2 groups:
1.) The balancer has spun and has incorrectly positioned the timing marks in a retarded postion. When you time to the marks, the timing is over advanced and results in pinging and poor performance.
2.) SPOUT circuit failure - bad/damaged wiring or TFI problems. Usually this will set code 18 when you dump the codes.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
