I'm at a bit of a loss here and I need you guys' help to make sure I'm not missing anything. Working with a '77 2.8L with approx 47K (or 74K can't remember for sure) Here's the problem:
This V6 Ghia I'm working on, I can't sem to get it to 'fire' correctly. It turns over fine and it will pop through the carb and every so often a pop out the exhaust. I've got good spark and I fool with the dist. as I'm turning it over. It just won't run, or even really do anything. I'm not much of a duraspark expert. I can get it hooked up but troubleshooting the duraspark is my weakness. New cap, rotor, good wires, new clean, correctly gapped plugs.
Then I thought hmmmm, maybe the valves are too tight but I really didn't want to remove all the smog crap...again... to pull the valvecovers but rather I managed to snake my compression tester and tested all 6 cyls.
#1 - 150
#2 - 145
#3 - 145
#4 - 155
#5 - 150
#6 - 145
Now I'm figuring that if the valves were too tight, I'd get much worse compression figures than that. Checked EGR valve, it's closing. Checked any and all other ports i knew were open, all plugged. I've changed out the coil and the DS control module and no changes. I'm feeding fuel into the carb with a small dripper bottle so I know I'm not flooding it out and that it is getting fuel. It just seems like the spark is occuring at the wrong time. I've brought #1 to TDC twice now and it's right where it should be in relation to the dist. cap. Checked firing order and rotation twice aswell. I'm just at wits end here and wondering if I'm missing anything else?
Signs are pointing to 'engine out of time' but I'm really reluctant to having to pull the front of the engine apart. Seeing as I have good compression, it's hard to think the cam is that far off time.... I dunno. Any input? Ideas? Thoughts? I just can't believe this thing is kickin my arse.
#1 - 150
#2 - 145
#3 - 145
#4 - 155
#5 - 150
#6 - 145
) Just got into a bit of a hurry, and it's looking like I'm gonna have to tear down the front again. However, the distrib spins and the valvetrain works perfectly without skipping a beat. And wouldn't the compression tell a tale if the engine is out of time? This engine being a 100% gear drive and if it jumps time, there should be major breakage on the cam gear and the valvetrain and dist would spin with a hesitation if any spin at all. The few V6s I've torn down that had the broken plastic gear usually are missing a good size chunk. So I dunno...
All this time I had been using some other firing order. I would have never guessed to check another book, as Haynes manuals have always been pretty good about continuity.
It runs! I feel like an idiot.
