Got my '66 started this past weekend after 3 years in hibernation.
Runs OK, but I am having trouble getting the idle down. What RPM should it be ideling at? I know need to time the ignition and tune the carb. What order should I work in? What should my inital advance be (At idle) and what total advance should I be shooting for? I assume with the new cam etc. I will not be at factory specs. Should I disconnect the vacuum kickdown on the trans. before I set the carb?
I also have an intermittant miss on one side that I only notice at idle. I am going to check the plugs and wires. Anything else that could be causing this?
Thanks in advance.
Thanks in advance.
seems like it is hard on the tranny to pop it into gear that fast. I bought an idle compensator solenoid to help with the A/C this time around, but I haven't got that far yet.
