Timing *?
  • Thread starter Thread starter MyCARneedsHelp
  • Start date Start date Apr 5, 2005
MyCARneedsHelp
658
Plainfield,IL
Apr 5, 2005
  • Apr 5, 2005
I just got in the garage to get my 5.0 running after my 2.3 gotten totalled and i noticed the timing sux. I have a few bolt ons edlebrock upper/lower, cold air, bbk shortys,h-pipe,a/c delete and so on. Its a manual 88 speed density. Where should i put the timing * at? thanx for the big help - Andy
F
fost9508
131
  • Apr 5, 2005
Try doing a search on "timing" or "advance timing" That should get you what you need. From my experience, which granted is limited it has been a trial and error sort of thing.
fost9508
Curse
791
El Paso, TX
Apr 5, 2005
  • Apr 5, 2005
Its something you have to play with to see where your car likes it. The best way to do it would be on a dyno, but if there is none near you could advance it in 2 degrees increments and take it for a drive everytime you advance the timing to see where it feels the strongest. Make sure everytime you advance the timing to listen for detonation. Good luck
notchback
1,950
St Clair Shores MI
Apr 5, 2005
  • Apr 5, 2005
go to 12* and leave it til you go to the track
make sure you pull the SPOUT out b4 you set it and don't forget to plug it back in when your done.
then next time at the track...run it, bump it to 14* see if your MPH goes up..don't look at ET if it does...go to 16* if some way it still goes up go to 18* but whenever the MPH slows down...go back to the point it was best. you can't do it by "feel" cuz it just doesn't make that much of a diff
E
1986 Convertable 5.0 GT
  • eneerg
  • Sep 24, 2025
  • The Welcome Wagon
The Welcome Wagon Sep 24, 2025
D
Fuel pump upgrade
  • dkrupp79
  • Jul 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Scrapla347
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Progress Thread 1989 LX 5.0 convertible - mild project
  • Scott_S
  • Aug 18, 2025
  • 5 6 7
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2026
DadLife0724
