Timing
  • Thread starter Thread starter 1990turbo
  • Start date Start date Jul 11, 2011
1990turbo
97
Portland, OR
Jul 11, 2011
  • Jul 11, 2011
I have a 76mm turbo on a 331. I have my timing set at 28 total Timing. I have been hearing that turbo motors need even less timing than that. It is running a little hot still maybe just a hint of pings much better than when it was at 32deg. Any help or opinions are appreciated.
Rick 91GT
Mustang Master
95
99
PA
Jul 11, 2011
  • Jul 11, 2011
Depending how much boost you ae making you may find you are in the 20-21 range total....
How is the car being tuned? What cyl head? What spark plug?
1990turbo
97
Portland, OR
Jul 11, 2011
  • Jul 11, 2011
TFS Twisted wedge heads NGK plugs heat range 9 accel fmu gen 6.
Rick 91GT
Mustang Master
95
99
PA
Jul 11, 2011
  • Jul 11, 2011
Id run a 8, which in the extended reach is a PT# 7173
What size inj? Be best to ditch the FMU if the inj are large enough and tun with the Gen 6. Do you have a good tuner that know the Gen 6, its old school and many guys don't know it, very decent system however.
1990turbo
97
Portland, OR
Jul 11, 2011
  • Jul 11, 2011
Isnt the accel gen6 the fmu. The box in the kick panel says accel fuel/spark management on it.
1990turbo
97
Portland, OR
Jul 11, 2011
  • Jul 11, 2011
So at the risk of sounding like an idiot I thought FMU meant fuel management unit and i figured that is what the accel box is. Believe me I am getting an education with this car
Rick 91GT
Mustang Master
95
99
PA
Jul 11, 2011
  • Jul 11, 2011
FMU is a device which has installs in the return line and boost fuel pressure under boost to add fuel. They are standard with most base blower kits so you can run the blower or turbo with a stock or small injector. You can swap disc to change the ratio they add fuel..
The Accel is the Stand Alone EEC or ECU
1990turbo
97
Portland, OR
Jul 11, 2011
  • Jul 11, 2011
No I do not have one of those. It does have a fuel pressure regulator on the fenderwell.
1990turbo
97
Portland, OR
Jul 11, 2011
  • Jul 11, 2011
The injectors are 55lbs and the pump is 500lph. And the plug by the dist needs to be out when i time it correct? And also any ideas on a/f mix? I dont have a guage yet but will get one in the next week yes it will be wideband
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Electrical Spark Plugs
  • jimzzilla
  • Feb 24, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 28, 2026
jimzzilla
1970 Mach 1 voltage regulator
  • 70ivygreen
  • Oct 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 27, 2026
Mcmahst
L
5.4 4v base ignition timing table help.
  • leoleo
  • Aug 16, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 17, 2026
MustangBetts
M
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
