Tire Pressure PSI for 18x9 with 275/35
What should my tire pressure be for everyday driving on the street? I have 18x9 rims with 275/35-18 at all four corners. The sticker in my glove box says 30psi front and rear, but that's for the stock 17x8 with 245/45-17. What's everyone running in their 18s??
Thanks,
WES
01PonyGT said:
The sidewall says max press is 44psi, but that's the maximum not necessarily the proper psi for every vehicle, right? Besides 44 psi would be an insanely harsh ride in a Mustang I would think.
WES
well i have 245/45ZR17's and they are at 35 PSI, so maybe run yours at 40 PSI?
Thanks for the replies 1990StangLX, but I was thinking I'd actually have to put less pressure than the OEM recommended 30psi because of the lower profile/stiffer sidewall of the 18" tire. Does that sound right?? Or am I just confused? How much psi are you guys with 18s running in you tires?
WES
01PonyGT said:
Thanks for the replies 1990StangLX, but I was thinking I'd actually have to put less pressure than the OEM recommended 30psi because of the lower profile/stiffer sidewall of the 18" tire. Does that sound right?? Or am I just confused? How much psi at you guys with 18s running in you tires?
WES
i see what you mean, but my thoughts were since you have a lower profile you'd have to add more air to keep that sidewall really stiff and prevent any possibility of rollover
Thanks,
WES
I was told 35 psi when i got my tires put on my new Afs 03 cobra 18x9's about 2 weeks ago. Share some pics of your ride;)
-wade
-wade
I don't have any pics that are small enough for stangnet....whenever I post a pic I have to reduce it's size. I'm running out the door now for a weekend trip so I'll post some when I return.
WES
