tire question....
  • Thread starter Thread starter 19stang87
  • Start date Start date Aug 17, 2004
19stang87
134
WoodStock,GA
Aug 17, 2004
  • Aug 17, 2004
how wide can i go on a lowered notch its a 87, i bought it lowered and dont know what parts he used to lower it but anyways how wide can i go....cause i found some 245/45/16s ....i know the 50s would rub had that problem last time on one side of the car when turning or hitting bumps in the road.....
thanks...
19stang87
134
WoodStock,GA
Aug 17, 2004
  • Aug 17, 2004
that question is for the fronts only sorry
thanks
19stang87
134
WoodStock,GA
Aug 18, 2004
  • Aug 18, 2004
anyone know?
UMDSmith
226
Salisbury, Maryland
Aug 18, 2004
  • Aug 18, 2004
I run 225's on the front, but just from reading around here, I wouldn't go wider then 245's on the front tires, and even then, you may have to adjust for a tiny bit of rub.
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
Aug 18, 2004
  • Aug 18, 2004
Stick with a 225. They track the road better than a 245 on the fox body. Plus they won't rub. On a 16" rim I'd look for a 225/50.
19stang87
134
WoodStock,GA
Aug 19, 2004
  • Aug 19, 2004
but a 50 rubs on the passenger side when i turn left or hit a bump.......umm well that was also b4 i put in a new rack in..might not be a problem now tho...
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Aug 19, 2004
  • Aug 19, 2004
my 245s are rubbing up front... i got mine lowered... it sucks... for some reason tha left side sticks out a little further than tha right and its really easy for it to rub on tha fender
19stang87
134
WoodStock,GA
Aug 19, 2004
  • Aug 19, 2004
so a 235 or stick with a 225 and see if a 50series rubs i guess?
FiveO
1,146
NJ
Aug 19, 2004
  • Aug 19, 2004
i have 245 50 16's up front lowered and it rubs a little.
will 255's fit in the rear on stock ponies? with quads in?
19stang87
134
WoodStock,GA
Aug 19, 2004
#10
  • Aug 19, 2004
  • #10
Do they rub cause of the 245s being to wide or the tire being a 50 and hitting up top....?????
Oh and 255s will fit without rubbing but a 255 is to wide of a tire for a stock pony rim.....wont wear right....dont go bigger then a 245....
04sleeper
2,674
14
89
Dallas, TX
Aug 19, 2004
#11
  • Aug 19, 2004
  • #11
I run 225-50-16's on the front and 245-50-16's on the rear. After many years of trying different combos this has been the best for me so far.
I wouldn't go any bigger than 245's in the rear. Even the 245 are a little big for the rim.
19stang87
134
WoodStock,GA
Aug 19, 2004
#12
  • Aug 19, 2004
  • #12
ya thats the combo i run as of now also but i need some new tires BADLY and was just curious on how wide i can go in the front without rubbing thats all........and my car is lowered quiet a bit.......is your car lowered at all 89sleeper???
04sleeper
2,674
14
89
Dallas, TX
Aug 19, 2004
#13
  • Aug 19, 2004
  • #13
Yes it is lowered. I have coil overs on the front and Motorsport C's in the rear. It's pretty low in the front. Just enough to give a good stance.
FiveO
1,146
NJ
Aug 19, 2004
#14
  • Aug 19, 2004
  • #14
width.
Marks5.0!
640
San Antonio, TX
Aug 19, 2004
#15
  • Aug 19, 2004
  • #15
same here
rubs the inner fenderwell when i turn it to full lock
Brads Coupe
Sweeeeet!!!
2,838
Calgary , Alberta, Canada
Aug 19, 2004
#16
  • Aug 19, 2004
  • #16
I run 255-35-18's up front and then only time it ever rubs is during slow hard turns. Other then that it never rubs.
black92gt
64
PA
Aug 19, 2004
#17
  • Aug 19, 2004
  • #17
I have 225/50/15 on 15x8 welds and they rub, anyone else roll their fenders with a baseball bat or something?
UMDSmith
226
Salisbury, Maryland
Aug 19, 2004
#18
  • Aug 19, 2004
  • #18
225/50/16's up front with no rub, lowered (I think with eibach lowering springs)
245/50/16 nitto DR's on the rear
Seems to be the best combo for most people.
Tires
  • 65er
  • Dec 18, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 9, 2026
Realmongo
305-45-17 tires on Pony wheels (17")?
  • TTSaleen
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 25, 2026
TTSaleen
Tire size question 1986 gt hatchback
  • B0udreaux
  • Jan 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 17, 2026
B0udreaux
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
