Tire size question
  • Thread starter Thread starter Santeeford
  • Start date Start date Dec 15, 2006
Santeeford
27
San Diego
Dec 15, 2006
  • Dec 15, 2006
I have a 93 Gt with the factory wheels. The tire size right now is 225/55. What is the widest i could go on that factory wheel?
Whytry91
321
Morrisville, NC
Dec 15, 2006
  • Dec 15, 2006
I have(had) 245s on mine, some people run 255s but that is pushing it...
04sleeper
2,674
14
89
Dallas, TX
Dec 15, 2006
  • Dec 15, 2006
I agree.
I ran 245-50-16's on the rear of my old coupe and 225-50-16's on the front.
Santeeford
27
San Diego
Dec 15, 2006
  • Dec 15, 2006
Thanks guys
Prime Lord
Crappy Default Title
2,137
199
114
Denver-ish
Dec 15, 2006
  • Dec 15, 2006
245/50/16 is the widest you can drop w/o overstressing the sidwalls.
DucatiRdr
271
North of Boston, Massachusetts
Dec 15, 2006
  • Dec 15, 2006
What about speedo error for the difference in tire circumference? My 88 has 225/60-15 with a circumference of 153.54". A 225/50-16 has a circumference of 143.53 for a difference of 6.5%. Is there a new speedo drive gear to account for the change in circumference?
Mustang5L5
Mod Dude
Feb 18, 2001
43,380
18,123
224
Massachusetts
Dec 15, 2006
  • Dec 15, 2006
WHy do you want to decrease tire diameter?
If you want wider rubber for your car, you can use a 245/55/15. This will keep your diameter the same and not require a gear change.
For the original poster, a 245/50/16 will also keep factory tire diamter and not require a speedo change
Prime Lord
2,137
199
114
Denver-ish
Dec 16, 2006
  • Dec 16, 2006
FWIW, its not the EXACT factory diameter, but its pretty damn close. B/t the 225/60/15 and 245/50/16 There's a .79" difference in overall height, leading to a .05" difference in circumference. At 60MPH, your speedo will be ~2MPH off.
Remember, when changing wheel size or tire width, the middle number of the three is the sidewall height as a percentage of the overall tire width. So as the width (first number) goes up, the sidewall percentage (second number) must go down to keep the overall dimension the same. The same is true when going to larger rims w/ the same width tire. The sidewall percentage must go down to accommodate the larger wheel.
225/60/15 ~= 245/50/16 ~= 245/45/17 ~= 245/40/18 and so on
so if you're sticking w/ a 15" wheel keep in mind that the sidewall must be tall enough to make the stock 15x7 wheel width. A 60 on a 225 is plenty. You can go to a 245/55/15 which are rare as crap, but its the exact same overall size.
DucatiRdr
271
Dec 16, 2006
  • Dec 16, 2006
For my '88 I wasn't looking to change overall wheel height, just tire width. I am going to pick up a set of 16" pony wheels and wanted to bump up the width from the OEM 225 to something a bit more asthetically pleasing. Remember, my '88 has the "old style" fenders/fender liners. I would like to avoid tire-fender contact and don't want to have to roll the fenders. Will a 245/50 16 fit the rear? Do I need to reverse the quads?
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Dec 16, 2006
#10
  • Dec 16, 2006
  • #10
I run 275/45/17 in the rear and 245/45/17 in front of my 93 coupe. peace
john
Prime Lord
2,137
199
114
Denver-ish
Dec 16, 2006
#11
  • Dec 16, 2006
  • #11
yes they will fit, yes flip em around
Mustang5L5
Mod Dude
Feb 18, 2001
43,380
18,123
224
Massachusetts
Dec 16, 2006
#12
  • Dec 16, 2006
  • #12
On my '88 i went from 10-holes to 16" pony wheels with 245/50/16 tires. The rear fit fine, the front had a little rub at full lock. Nothing major.
I know have 245/45/17" tires on it
Brett88lx
65
#13
  • Dec 16, 2006
  • #13
I have 255's on the rear and 225's on the front. Very little rubbing, nothing major at all. Good luck.
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
wheel fitment?
  • 387lx
  • Nov 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 14, 2026
387lx
Tire size question 1986 gt hatchback
  • B0udreaux
  • Jan 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 17, 2026
B0udreaux
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
Drivetrain Tail Shaft bore odd shape
  • R82148V
  • Jun 12, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Mustang5L5
