Kilgore Trout said:I believe that different size tires can cause ABS problems, but I am not 100% sure about this. Do you have ABS?
That's interesting because the way ABS works is that when it detects one wheel turning at a different rate than the others, it activates the brakes. I wonder how it does this if it never compares the rates of spin to each other. Must be magic I guess... NOTghstrdr said:It will not mess with the ABS Because each wheel is controled indivdualy the rear is not linked to the front and the left side is not linked to the right in any way
