TKO 500 in a 65
  • Thread starter Thread starter 65FBE2
  • Start date Start date Mar 14, 2007
65FBE2
283
Minnasnowta
Mar 14, 2007
  • Mar 14, 2007
Has anyone put a TKO500 in to a 65 or 66 mustang? I have been told by the guys at Dark Horse that it will not fit without modifiying the tranny tunnel. I spoke with Keisler Auto and they said they make a kit that will fit with only minor mod. to the cross member at the top of the tunnel. But after quetioning them a little deeper, they have never put one in a 65-66, only 67-70. Dark Horse told me that the tunnel in a 65-66 is slightly smaller. If anybody has done this swap let me know what you went through
G
Gailahan
144
St. Louis, Missouri
Mar 14, 2007
  • Mar 14, 2007
To get the right driveline angle on a 65-66 the transmission tunnel will need to be raised.
65FBE2
283
Minnasnowta
Mar 15, 2007
  • Mar 15, 2007
Thats what I've heard. I have been concidering a Gearvendors overdrive unit and keeping the toploader. That way everything fits. But you only get a .78 overdrive, althought splitting the gears could be cool.
SnakeStang65
160
Jasper, Indiana
Mar 15, 2007
  • Mar 15, 2007
If you do not need the TKO 500, do not put it in. The t-5 will be a better fit. I have a 3550 (500) installed in mine, and it required cutting the tunnel to get it in correctly. The driveline angle without rasing the tunnel was over 6 degrees, after raising the tunnel it is the correct 3 degrees. There have been many discussions about this issue, and some people will tell you that it will fit. If you want it to fit correctly, you will have to cut the tunnel. A T-5 will also have driveline angle issues, but they will not be near as bad as a TKO 500/600 series transmission.
I have a few photos on my website if you want to see what I had to go through...
John
65FBE2
283
Minnasnowta
Mar 15, 2007
  • Mar 15, 2007
Thank you very much! This is exactly what I was looking for. I wanted to see the job done right! I have just finished a rotissiory restoration on this car and am in no hurry to cut up what I just paid big money to be repaired. I am set up for road racing and think that the gearvendors unit is looking better all the time. Your car looks great! Mine is the reverse paint (pearl white with pearl blue strips) I would attach a pic, but I can't figure out how to attach with out going over the kb limit
SoCalCruising
2,437
SoCal
Mar 15, 2007
  • Mar 15, 2007
The Gear Vendors will add weight, but at least it's in a pretty good location. The G-Force T-5 might also be a consideration if you don't think that the Motorsport T-5 will handle the power you have. Not many guys trash their Motorsport-spec T-5s because it's tough to fit enough tire in the wheel well to really stress the tranny. If you are building a real hi-hp road race machine with sticky tires, you might need more.
67 Evil Eleanor
66
SW Virginia
Mar 15, 2007
  • Mar 15, 2007
Is this the same with the 67-8's?
P
PJx5x
197
Chicago
Mar 15, 2007
  • Mar 15, 2007
TKO is based on the 3550.
TKO 500/600 is based on the 3650.
SnakeStang65
160
Jasper, Indiana
Mar 16, 2007
  • Mar 16, 2007
Careful there chief...
"The TKO 500 & 600 share the same case and dimensions are the previous TR-3550, TKO, and TKO II." (From the link below)
Take a look here.
The 3650 is what I have in my 03 Mach1 and it is no where close to the same transmission.
latamud
791
Tampa, FL
Mar 16, 2007
#10
  • Mar 16, 2007
  • #10
Take a look here.
Is the 3650 similar/same dimensions as the T56?
67 Evil Eleanor
66
SW Virginia
Mar 17, 2007
#11
  • Mar 17, 2007
  • #11
So I'm a little confused, I have put two of these in. One in a 67 and the other in a 68. No problems. So it sounds like the 65-66's have to be cut and the 70 has to be cut also. Can someone clarify this?
J
Jimmys66
419
Paw Paw MI
Mar 18, 2007
#12
  • Mar 18, 2007
  • #12
Any 5-speed trans that you don't need to cut the tunnel for?
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Intended Headers and Trans, questions about fitment
  • from6to8
  • Aug 6, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 6, 2025
from6to8
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
M
  • mnky99
  • Sep 5, 2025
mnky99
M
