TKO 600 PROBLEMS
  • Thread starter Thread starter stick
  • Start date Start date Jun 8, 2006
stick
9
  • Jun 8, 2006
I have the trans in but when I installed the driveshaft, the driveshaft will not rotate. The car is in neutral. I no im not bottemed out because i can move the driveshaft forward into the trans more. Also Im not sure the trans shifts into 1st. Does it barly go into 1st? I have an aluminum driveshaft with the 31 spline slip yoke. The crossmember is modified, Mcleod bellhousing and have a new clutch disk. Does anyone have any ideas?
Thanks
Ryan 92 stang
Sicarius428
2,085
Jun 8, 2006
  • Jun 8, 2006
Did you have a chance to shift the trans out of the car and rotate the input shaft? Was it able to into all the gears and watch the output rotate?
Kevin
stick
9
  • Jun 8, 2006
I was able to shift through the gears with the trans out of the car, had the same problem with first tho. didn't look if the output was rotating, sounds like the trans is coming back out.
Sicarius428
2,085
Jun 9, 2006
  • Jun 9, 2006
I am in the middle of instaling my TKO600. I just finished putting my yoke on the DS last night and making some delrin spacers to use my stock shift handle(really broke now). I was able to go through all the gears. It wasn't that smooth but I figured as much due to no fluids. Did you pull that rubber seal where the yoke goes? I wasn't able to turn my over by hand with it in. Sorry to hear your gonna pull it most likely.
Kevin
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
C
5r55s auto to TR3650 Manual swap 4.0 V6
  • Ceskz
  • Feb 24, 2025
  • 2005 - 2014 Specific V6 Tech
2K
2005 - 2014 Specific V6 Tech Mar 27, 2025
89ripper
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
