TKO Help
stripped302
84
Shelby Twp, MI
Hey everyone, i have a 84 gt and with the weather warming up i'm ready to start installing the parts i've stock piled over winter. i just want to make sure i purchased everything i need.
the car has the stock trans i purchased a tko 500 from the roush garage sale and it was also previously installed on a early fox so i believe its 10-spline going of memory from when i last saw it and already has the cross member attached and i believe a early fox bellhousing. do i need any drive shaft or input/output shaft parts? or should everything bolt right up with the 10.5in flywheel and clutch kit i purchased?
thanks just wanted to double check because i believed it was a straight swap if the shafts were 10-spline, and never heard of needing to change yokes or drive shafts till i dug around a bit, but that was with people using 26-spline.
