TKO install questions????????
  • Thread starter Thread starter Numbles
  • Start date Start date Apr 14, 2005
Numbles
998
Chicago, IL
Apr 14, 2005
  • Apr 14, 2005
Whats up everyone. Im usually in the 94-95 section but I totaled my 95 about 4 months ago and just recently picked up a 93 lx. Im in the middle of swapping my tko600 into the 93 but I know there are going to be a few snags.
1) Can anyone explain how to modify the crossmember. The 95gt's just need you to turn them around, is it the same for fox's. Anyone have a picture of how they modified theirs.
2) I needed a driveshaft spacer for my old car but I heard the trans was designed for fox cars. Can I just get an aluminum ds from frpp with the 31 spline slip yoke and will the length work. I think its 45.5".
3) I have a poly mount for the trans. Do I need to get ajustable control arms to get the pinion angle straight again or will it be fine.
These are just a few questions I have off the top of my head. I did a search and these were the only ones I was still unsure on.
Thanks
Dan.
slytherin
702
northeast ohio
Apr 14, 2005
  • Apr 14, 2005
#2 you should be fine with out a D/S spacer.
Stang8URMPRT
1,100
Daytona Beach, FL
Apr 14, 2005
  • Apr 14, 2005
I believe the TK-600 is like the TKO of old... Needing a 26 spline clutch disc, and a 31 spline yoke for the driveshaft. The crossmember needs to be modified... All I did was file the mounting holes for the trans mount farther BACK, towards the rear... Takes about 3/4 of an inch filing for each hole. The driveshaft will work fine, just need a 31 spline yoke. Other then that.. it fits fine... Also needs the special bellhousing, but I'm sure you knew that.
Numbles
998
Chicago, IL
Apr 14, 2005
  • Apr 14, 2005
For the crossmember I read in another thread that you have to cut the welds and move the crossmember forward. And you say back. Is it dependent on the car or was that person wrong.
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Apr 14, 2005
  • Apr 14, 2005
The cross member needs to be moved back. This can be done by grinding the welds on the stock one or picking up a motorsport cross-member which comes without any welds. You will just have to put some tack welds on once you get the trans bolted in. A drive shaft spacer is not needed on the foxes. Your trans mount is fine. I used an energy suspension mount. Furthermore, I used an FMS aluminum driveshaft with a 31 spline yoke and the length is perfect. Only other thing I can think to tell you is to pick-up the correct gear drive and bellhousing/scattershield for your application. If you run a scattershield then pick up a pro-motion extended clutch fork. Good luck.
Numbles
998
Chicago, IL
Apr 14, 2005
  • Apr 14, 2005
I used to drive the tko with the 21 tooth (White)speedo gear. But its a little bit off. Anyone know what the correct speedo gear is with a tko. The drive gear is different. With 3.73's
Stang8URMPRT
1,100
Daytona Beach, FL
Apr 14, 2005
  • Apr 14, 2005
Yes.. You can also do it that way, but then you will have to have it rewelded. I'm talking about the slots on the crossmember where the trans mount bolts to the crossmember. You can grind those slots longer... that will give you the clearance you need without having to cut the welds and then have it rewelded.
Nick
Brads Coupe
Sweeeeet!!!
2,838
Calgary , Alberta, Canada
Apr 15, 2005
  • Apr 15, 2005
I recently purchased a TKO-600 as well. These are things that I was told that I had to replace.
Driveshaft
Bellhousing
Clutch
and Yolk
Good Luck with your swap.
Blown stocker
11
  • May 3, 2005
why the 600 and not the 500
Driveshaft
Bellhousing
Clutch
and Yolk
why did you end up going with the 600 and not the 500 ?
mstangfrk95GTS!
203
#10
  • Jun 18, 2005
  • #10
i went with the alternate gear ratio and the 100 more ft lbs handling, the stronger the better..
CRASH7772
401
NH
Jun 18, 2005
#11
  • Jun 18, 2005
  • #11
You can get away with a auto crossmember out of a 87-93 as well or laurelmountainmustang.com sells them new for $40.
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
Kleinjj27
K
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
