TKX Install in the Coupe
  • Thread starter Thread starter AeroCoupe
  • Start date Start date Apr 12, 2025
  • 3
First Prev 3 of 3
nicholase
I lubed and pushed, until it was all the way in
May 21, 2024
659
1,182
103
New York
May 25, 2026
#41
  • May 25, 2026
  • #41
Hey, I'm gathering up stuff for this swap. The TKX input shaft is the same diameter as a T5 right? Same pilot bearing correct? Like this guy: https://lmr.com/item/LRS-7600A/79-95-Mustang-50L-Clutch-Pilot-Bearing
J
JMG9350
48
27
28
Wyoming
May 25, 2026
#42
  • May 25, 2026
  • #42
Yes. Same bearing.
Reactions: nicholase and AeroCoupe
AeroCoupe
6,186
4,283
183
Claremore, OK
May 25, 2026
#43
  • May 25, 2026
  • #43
Same pilot bearing and Fox length. They do not (to my knowledge) make a 94/95 specific length input shaft.
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,518
2,941
173
Florida
May 25, 2026
#44
  • May 25, 2026
  • #44
I believe there is no difference, but slide the pilot bearing on your trans BEFORE you install it to make sure it fits ..... Learned this lesson 50 years ago helping a friend install a 289 in a 57 ford...... Spent over a week trying to get that trans in before we pulled out the pilot bearing and found it would not go on the input shaft...
Reactions: nicholase and WhiteCobra95
nicholase
May 21, 2024
659
1,182
103
New York
May 25, 2026
#45
  • May 25, 2026
  • #45
Thanks guys
AeroCoupe
6,186
4,283
183
Claremore, OK
May 25, 2026
#46
  • May 25, 2026
  • #46
I can absolutely tell you there is no difference. Pulled the T5 out and never changed the pilot bearing. It had maybe 5K miles on it so I didn’t go thru the hassle of changing it.
nicholase
May 21, 2024
659
1,182
103
New York
May 25, 2026
#47
  • May 25, 2026
  • #47
I was hoping that's the case. I'm gonna pop a new one in, but just want to make sure I have all the stuff when I get started. Probably gonna do it shortly and want limited down time.
I got the MGW shifter in. Seems high quality.
Reactions: gkomo
limp
5 Year Member
Oct 4, 2020
5,518
2,941
173
Florida
May 26, 2026
#48
  • May 26, 2026
  • #48
We have all done it but hammering in the pilot bushing/bearing is not a good idea... I watched a video recently where a steering wheel puller was used to push one in.. Gonna try this next time at my place....
Admin Dude
Jan 4, 1985
43,531
21,699
234
Box behind Walmart
May 26, 2026
#49
  • May 26, 2026
  • #49
Use a socket that matches the bearing face, give it a little lube, and TAP it in... Done.
Reactions: AeroCoupe and nickyb
  • 3
First Prev 3 of 3
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
Drivetrain GM T56 in a Foxbody
  • AeroCoupe
  • Sep 19, 2024
2K
Fox 5.0 Mustang Tech Sep 20, 2024
AeroCoupe
A
88 Foxbody Starts but Stalls When Warm Please Help
  • airforcerob
  • Apr 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2025
