  • 1994 - 1995 Specific Tech
Drivetrain TKX Shifter Position Question
  • Thread starter Thread starter fasterthangas
  • Start date Start date May 29, 2026
  • 3
First Prev 3 of 3
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Jun 25, 2026
#41
  • Jun 25, 2026
  • #41
from6to8 said:
Hey Kurt, did you index the bell? The 95 I bought in 2016 has a lakewood scattershield and I'm removing it for this 331 setup. I have the appropriate bell to use and talking to a few guys that I know personally, they have never indexed any Tremec they've had and didn't have any issues.
Yes, and I had to make an adjustment. There is a video of how to do it on my Magnum install thread that is very good. It has nothing to do with the quality of the bellhousing. The crank line honing process done to the engine can cause the crankshaft to not be exactly centered in the block causing misalignement with the transmission input shaft. It's generally not required for factory engines that were assembled OEM by Ford. Like if you took a stock 5.0 car from 30 years ago and just through a transmission on it, you would most likely be fine. Any engine that has been built outside of a Ford OEM plant absolutely needs to be indexed. It's a simple process, and it just requires a few offset dowels to make it right. No reason to fear the index process.
Kurt
Reactions: nicholase, fasterthangas and General karthief
WhiteCobra95
641
180
74
Jul 4, 2026
#42
  • Jul 4, 2026
  • #42
Kurt
Thanks for the detailed explanation, Kurt! That makes perfect sense.
  • 3
First Prev 3 of 3
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
AeroCoupe
TKX Install in the Coupe
  • AeroCoupe
  • Apr 12, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2026
