to bondo or not to bondo, that Is the question?
H8Eternal
51
queens NY
I just took of my wing and Im going to stick without one. My question Is, the 4 holes that Is left on the decklid, what can I fill them with before I get It repainted? I've worked with bondo before so It's not like It's going to be a hard task for me. but Is bondo strong enough or should I use something else.
thanks
steve-
bondo would work.......i've done it with bondo and a metal patch on the underside and worked fine. but the best way to do it....if you know how to weld....is fill the hole with a weld.start at one spot on the hole and work your way around in a back and forth motion. then grind it smooth. you might need a light layer of bondo over it to fill the imperfections. hope this helps ya.
I'm taking an autobody class at college
Couple things you could do
Fill the hole with a weld, grind and bondo, and 'glazing putty', feather the paint, prime and paint.
Use either epoxy, or panel adhesive to glue a metal plate to the bottom, use "all metal", then bondo, glazing putty, prime and paint.
I took the "ford" emblem off the back of my fox. I put a piece of fiberglass webbing behind the holes, then used "bondo-glass" (its a bondo compound with fiber to make it stronger) i filled the holes, sanded it smooth, then puttied it. cant tell it was there.
