To Boost or not to Boost?
  • Thread starter Thread starter matador91
  • Start date Start date Mar 7, 2009
matador91
107
31
38
Bothell
Mar 7, 2009
  • Mar 7, 2009
So... I am wanting to through the AFM, Stage II Vortech SQ-Trim Kit (14 lb boost) on my car but I'm afraid the compression ratio is to high " 10:1" If it's not how much boost would be safe.
Jaswir
578
Orlando, FL
Mar 7, 2009
  • Mar 7, 2009
i would say 6lb... never know untill tuned
Cobra_Dusten
246
Marysville, Wa
Mar 7, 2009
  • Mar 7, 2009
10:1 is way to much compression for more than a few lbs of boost, 5-6 is all i would throw at it. with compression that high, boost is going to raise your static compression ratio beyond that of which you can safely run pump gas
blownsn95cobra
Jeannette
Mar 8, 2009
  • Mar 8, 2009
to high to run that much boost 5-6 would be safe bet like they said dont want to go and blow or melt anything unless your trying to like me so i have a reason to build a motor but i am running 12psi on 9:5:1 bone stock 5.0 block and heads and untuned for now soon to get tuned and it will not just blow up hahahah
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
