To seal or not to seal, intake manifold gasket
if your talking about the cork that seals the back and front of the intake then yes i totally agree. use the ultra black as it will hold up agains the oil in the lifter valley. use a big thick line of it and slap it on there finger tight. after bout 5 minutes then i tourque it down. make sure your intake gaskets seal too cdause you dont want water getting into your lifter valley an into the oil.
later,
tommy
I would recommend throwing the cork gaskets as far as you can fling them. I use a new type of gasket sealer called "the right stuff". This is the same gasket sealer that the big three all use today. It works great and I have never had a leak since using it.
I just installed a performer rpm intake and used the cork end pieces. Well, the rear one moved a little and didn't seal. Then I threw them in the trash and used silicone with no problems.
I say trash 'em.
