Engine Too much vacuum?
Flatfoot
5 Year Member
Aug 18, 2017
72
96
38
Milton, Fl
1988 mustang H/C/I car. The previous owner removed the fitting from the throttle body that the hose attaches to that runs to oil filler neck on the valve cover. He had the hose attached at the oil filler neck and run down towards the ground venting to the atmoshpere. Soooo i have unmetered air coming into the engine. The throttle body where the fitting is supposed to be is capped. Can I just cap the side of the oil filler neck or will this cause too much vacuum in the motor?
If the engine's PCV system is working properly, capping the oil filler vent shouldn't cause any problems. Check the oil separator screen in the PCV hole in the block to make sure it isn't clogged or damaged.
Reactions: 1 user
Do not cap the one on the filler neck. That is supposed to be the draft. In the back has a check value so if you cap it there could be situations you have no crankcase ventilation.
if not already do cap the stem on the throttle body.
adding a tiny filter to the one on the filler neck would be a good idea, just keep an eye on your oil for water dilution. ( milky stuff on the fill cap)
Sorry if I interpreted the Op incorrectly but, it reads to me like you are mistaking the nipple on the filler neck as a place of engine vacuum. This is not the case. That is where your crankcase ventilates. (Blow by gets out there) it's imperative that gets vacuum, or atmosphere. Otherwise things like valve cover gaskets, oil pan gasket, dipstick.. will be under pressure until something gives out.
'88's don't have a meter.
