I went to re-gap the spark plugs and took them out. Five of them were oil-fouled. So we ran a compression test and the compression came out fine. So I guess the oil problem is with the valve stem seals?
Also, on our old engine (also a 351w, originally a 2 barrel and therefore a 9-9.5:1 engine) would usually show compression readings for 140-160 psi on all cylinders when healthy. This engine showed readings of 180-200 psi on all, which is more indicative of the 351 4 barrel (which I think was 11:1 stock) version... would you all agree? This would explain the ping I've been experiencing, and would also dictate what I should gap the plugs to.
Thoughts on both?
Thoughts on both?
