Tool advice
  • Thread starter Thread starter golf4283
  • Start date Start date May 16, 2004
golf4283
1,253
Orland Park, Illinois
May 16, 2004
  • May 16, 2004
Can someone please tell me what hte best way to strip the engine bay is?? Should i use an angle grinder or something like that?? I am just about ready to get started and was just wondering what is the best/easiest way to get this job done. Thanks Stangers!
Hack
1,945
Minneapolis
May 16, 2004
  • May 16, 2004
Lots of ways, depending on your preferences.
For fast and easy, sandblasting is probably tops. Especially if you pay someone to do it for you. I think the best way is to have the entire car disassembled and take it to get blasted. But if you're just doing the engine compartment, it doesn't seem like that great of an idea to me. The sand gets everywhere.
After that, chemical stripper does a lot of work for you and speeds up the job.
I see where a lot of people here use a wire wheel or sandpaper discs. The posts I have read seem like it was a lot of work and time spent.
I'm not sure of other options. Probably start with stripper, then clean up the rest with a wire wheel.
golf4283
1,253
May 16, 2004
  • May 16, 2004
ok that sounds good with the stripper. can you recommend a brand and where to get it? like would home depot have it or something?
muddslide
505
DAYTONA BEACH
May 16, 2004
  • May 16, 2004
I used a good paint stripper and sand paper, worked great and was fast.
85GTlover
704
  • May 16, 2004
For tight spots a drill with a wire wheel or a dremel type tool works very well, I too am in the process of doing that along with other extensive work on my car, stripping is a good idea, I just used tools to remove the paint, a grinder with a special wire wheel $20-30 works great but cannot reach many areas, that is why the drill and Dremel come in handy. Good luck.
Hack
1,945
Minneapolis
May 16, 2004
  • May 16, 2004
http://forums.stangnet.com/showthread.php?t=448803&highlight=chemical+stripper
try this thread. I did a search for "chemical stripper". This and a bunch of other threads came up.
Engine Obstinate Pilot Bearing removal
  • FastDriver
  • Feb 12, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 22, 2026
manicmechanic007
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 21, 2026
keel
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
