Tool needed for Trick Flow upper intake
  • Thread starter Thread starter spoulson
  • Start date Start date Nov 22, 2009
spoulson
76
Middletown, DE
Nov 22, 2009
  • Nov 22, 2009
I'm tearing down the top half of the engine and was quickly stopped by the upper intake. I bought this car with the Trick Flow Street Burner intake already on it. There are two 12 point 3/8" bolts in the center that I can't seem to find a way to get at. Standard 12 point sockets are too fat to fit in the recess.
I suspect nut drivers or thin walled sockets might work, but it seems nobody local sells these in 12 point. Even then, I'm not sure which would fit or not until I've already spent the money.
What works for you?
J
jerryD
1,061
Gladstone, MO
Nov 22, 2009
  • Nov 22, 2009
i could a swore it was a 5/16 12 point. when i get home, ill look at the socket i use.
ID89GT
1,659
18
49
Spokane Valley, WA
Nov 22, 2009
  • Nov 22, 2009
A 1/4" drive might work better, they are usually smaller in size for gettin into small areas
J
Joey7508
198
Kerrville TX
Nov 23, 2009
  • Nov 23, 2009
12 points in the middle are 5/16 the four lower are 3/8 or 10mm will work.
spoulson
76
Middletown, DE
Nov 23, 2009
  • Nov 23, 2009
Ahh, and the 12 point socket set I bought only goes down to 3/8". Doh.
Thanks for checking.
spoulson
76
Middletown, DE
Nov 30, 2009
  • Nov 30, 2009
Btw, it was a plain old 5/16" 12-point for those bolts. Thanks for the help, guys.
F
frcefedlx
184
  • Nov 30, 2009
I use a regular 12pt craftsman socket 1\4" drive no problems for me.
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Nov 30, 2009
  • Nov 30, 2009
snagged me a new craftsmen set this weekend, black friday sale ftw.
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
