Top end kit gasket set HELP
  • Thread starter Thread starter banks98stang
  • Start date Start date Jan 24, 2012
banks98stang
57
  • Jan 24, 2012
ok i have a 306 bottom end
edolbrock performer heads
holley systemax uper lower intake
ok heres my ? im going to remove the upper n lower to remove 1 head n needa know what kinda gasket kit i should purchase
i know i can find out when i take these things off but does ne one know right off hand what ill need? where i can order them ?
txstang84
1,639
42
69
Tuscola, tx
Jan 24, 2012
  • Jan 24, 2012
This should be the correct one for the upper to lower mating surface...
http://www.summitracing.com/parts/HLY-108-80/
The lower to heads will be one of many...I used Mr Gasket 5834, and Fel-Pro 1250 with great success...
Ford racing sells several under their moniker as well-they're all Fel-Pros...sometimes cheaper. Summit sells everything you need for this particular operation...
Rick 91GT
Mustang Master
95
99
PA
Jan 25, 2012
  • Jan 25, 2012
I would match the head gasket to the other side if your only pulling one head....stock replacement cyl head gasket would be a Fel-Pro 8548-pt2 or an upgraded graphite gasket is 9333. The holley number listed above is correct for upper to lower intake, although the Holley lower is closer to a Fel-Pro 1262 (intake to head)
txstang84
1,639
42
69
Tuscola, tx
Jan 25, 2012
  • Jan 25, 2012
Really? I didn't think the ports were that big...hmm! I recall reading a while back, the upper to lower gasket on the Holley intake is/was the same as the EFI truck intake-any truth to that one? I never messed with the systemax pieces...
Rick 91GT
Mustang Master
95
99
PA
Jan 25, 2012
  • Jan 25, 2012
The holley lower has went through a few changes it may be a little closer to a 1250 now, but I find them to be as tall as a 1262, but maybe not as wide...running the 1262 wont hurt a thing.
Comparing the Holley lower to a EFI truck intake is life comparing a F350 to a Smart Car The upper to lower is near identical gasket wise
txstang84
1,639
42
69
Tuscola, tx
Jan 25, 2012
  • Jan 25, 2012
Ha ha! Yeah, that's all I meant was the gasket...
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
Engine Explorer - Lower intake internal cleaning
  • R82148V
  • Nov 11, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Dec 6, 2025
rednotch
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
