top end power
  • Thread starter Thread starter slow93
  • Start date Start date May 6, 2005
slow93
406
  • May 6, 2005
i was wondering if anyone has any ideas to boost top end power with bolt ons for a stock motor.i am runnin 4.10 with a five speed and the car launches great but in third and fourth gear it seems to die off somewhat.any ideas???
NKau
1,346
Jefferson, WI
May 6, 2005
  • May 6, 2005
What's done to your motor? The lower intake is the biggest bottleneck on a stock engine.
slow93
406
  • May 6, 2005
cia,air and smog removed and thats about it
302GT
81
Carson City,Nv.
May 6, 2005
  • May 6, 2005
Get an x pipe.That help on my top end.
NKau
1,346
Jefferson, WI
May 6, 2005
  • May 6, 2005
An intake will give you the best bang for the buck. If you are keeping the stock heads for a while, look into the edelbrock performer (not RPM), TF street heat, Cobra, GT40, or one of Tmoss' ported stock lowers. Will pull harder into the 5K range, until the stock heads start to choke; should be worth somewhere in the area of +/- 20 HP at the rear wheels in the upper rpms.
dcarlson
128
Long Island, NY
May 6, 2005
  • May 6, 2005
I second the intake and X pipe. Both will shift the power to a higher rpm and make more top end power.
Can I assume you've bumped the timing? Shorty headers are also a good mod for the '93. (More gains than you would get on a later '94-95 5.0). If you are going to keep the car mostly stock, get the MAF bored to 60mm. It's good for about 5 hp at higher rpm. If you are panning to do more serious mods later, skip that and just wait and buy a good 80mm Mass Air later when you do the rest of the mods.
NKau
1,346
Jefferson, WI
May 6, 2005
  • May 6, 2005
If he sticks with the intakes I listed, he won't lose anything on the bottom end either. There are also a lot of things I would spend money before buying an x-pipe as well..........
slow93
406
  • May 6, 2005
what years did the explorer have gt40 intakes and are they any good
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
