- Apr 19, 2007
- 28
- 0
- 0
i just got done putting the top half of my motor together yesterday and now ive got a rough idle and when i stab the gas pedel it bogs down to about 600 rpms and then comes back up. it also likes to bog and die when i start out from a stop forward or reverse unless i rev it up a bit first.
heres a list of whats been done:
track heat upper and lower intake manifolds
24# injectors
75mm maf matched to the 24# injectors
bbk fpr
bbk equal length ceramic headers
msd drop in billet dizzy
bbk 70mm tb
egr, smog pump, and purge can delete(these were done with the ron morris motorsports delete kits)
tfs tw track heat heads
the following mods were already on the car when it was running fine before the above parts went on:
bbk fenderwell intake
2.5in off road h pipe
msd wires
msd coil
bbk underdrive pulleys
edit: also not getting any codes. other thoughts are that i might have a vacuum leak somewhere but that would have to be one hell of a vacuum leak right?
24# injectors
bbk fpr
bbk 70mm tb
msd wires
msd coil
