Ok, Hopfully I can describe this without the use of pictures.
Originally my mach 1 had been converted to a racer. The shifter linkage has been moved about 4-5" left of the correct location. They had placed spacers along the transmission (before the shifter) which accomplished (what they thought) was a better location for the shifter. This also resulted in my transmission tunnel being splayed open.
I have repaired the tunner and have the correct location re-established.
As I am restoring the car back to proper form and need a good picture of exactly how the shifter should be sitting in contrast to the transmission.
Even better a link to the correct linkage would be great. (ie.e mustnags unlimited or other retailers). I have the hurst shifter. It's clearly obvious to me the linkage (regardless of functionality) I have isn't correct because of the shifter location. I cannot tell if the shifter needs to be elevated and moved or if removing the spacers and getting new linkage is enough.
I will post a picture when I get home.
Mike
Mike
