Toploader stuck in 3rd?
  • Thread starter Thread starter DK832
  • Start date Start date May 15, 2006
DK832
291
Copenhagen, DK
May 15, 2006
  • May 15, 2006
I have a Toploader behind a very healthy 351W, delivering to a 3.70 geared 9" with Detroit Locker. The Hurst shift is sloppy and I'm waiting for the complete install kit from Summit to redo the control box.
Saturday I'm out cruising and during an accelleration 1-2-3rd I'm unable to shift to 4th or even get it out of 3rd.
My mechanic tells me that this can happen and that 2 gears are selected at the same time, preventing anything from happening. I did drive it home in 3rd, so how can that be?
He tried readjusting the sloppy rods, putting in some spacers etc. but it will eventually get stuck in either 2nd or 3rd. He thinks something more than the control box might be affected. I'm not very knowledgeable about Toploaders besides what I read on Toploaderheaven.com, so opinions appreciated!
Will the install kit (control box) fix the issue or should I take the tranny down and go through the insides as well? The tranny (and not the shifter) was redone 5 yrs ago and has had about 20.000 mi on it since.
69 Rustang
307
Orange County California
May 15, 2006
  • May 15, 2006
I do know a sloppy shifter can cause these problems (and a good one prevent them). When I was running the stock shifter in my 69 it would occasionnally get stuck between Reverse and 1st--which locks your tranny and you can't go anywhere!!! I would have to rock the car while jimmying the shifter to unlock it to move again. Finally I upgraded to a new Hurst Comp Plus and the problem never recurred again. If you have bent the shift forks, well that could be another problem...
dennis112
1,561
36
79
Amish Wonderland of Central PA.
May 15, 2006
  • May 15, 2006
A bad shifter will give you all kinds of problems.
I am not saying that you didn't break something inside the tranny, but the design of the toploader shift rails (inside the case) pretty much prevent you from putting it into 2 gears at once. You certainly are only in one gear if you were able to drive home.
DK832
291
Copenhagen, DK
May 16, 2006
  • May 16, 2006
Thanks, I'll fix the control box and see if that fixes all problems then.
D
D.Hearne
11,730
south louisiana
May 16, 2006
  • May 16, 2006
Most times this happens it gets hung between reverse and 1st. All you need do is get it fully into reverse then it'll come back out. Or get under the car and remove the shift rods from the shifter and then you can work them on your own to get it un-hung. When you can do this in the dark, without a flash light on the side off the road, with out tools, you're truly an expert, or rather one step from it. Once I figured my Toploaders were hung between gears and what casued it ( slipping it halfway into reverse while trying for 1st) it's never happened again. Even my 20 year old kid's adept at it. He first did it when he was 16.
2nd Mustang
2,488
Southern California
May 16, 2006
  • May 16, 2006
My top loader got stuck in second gear before I had the transmission rebuilt. I had just stopped and was trying to "clear" the neutral gate as I had trouble getting it into first at times which required me to drop it into second then first. Good luck.
DK832
291
Copenhagen, DK
May 16, 2006
  • May 16, 2006
That's what I ended up doing. Had to use a wrench to operate the frontmost of the shift levers with a good deal of force. Is that normal or should it move easily?
Will driving it stuck in a gear damage anything? I drove it 15 mi home stuck in 3rd the first time. Hope that wasn't too stupid...
D
D.Hearne
11,730
south louisiana
May 16, 2006
  • May 16, 2006
They'll usually come out of a hung position without using a wrench on the shift lever. The front most lever is 3-4th. rear one is 1-2. Middle is reverse. And no it won't hurt it driving it. If it was truly hung between gears in the transmission, it wouldn't go anywhere. As in 1st & reverse. The shifter is what's hung up.
RMODEL65
313
brunswick ga
May 16, 2006
  • May 16, 2006
yeah my tranny was stuck i removed the shift linkage like above it was stuck in a gear? i moved the all the levers and now it works smoothly! but i did the linkage on the tranny its self instead of the shifter so i wouldnt have to readjust the linkage! then i decoded the tag on the tranny its coded heh-t for a 289 hipo close ratio anyone recommend gears in the rear end for this tranny? its close ratio! i got a mild crane cam?
F
fastback brian
540
So Cal , I.E.
May 17, 2006
#10
  • May 17, 2006
  • #10
First thing sounds like a worn shifter assembly and if your adjustment and shifter is over shifting your trans then it can cause damaged to the shift rails, detents or sliders. best thing to do would get a new hurst shifter/linkage and carfully adjust the linkage and shift stops.
D
D.Hearne
11,730
south louisiana
May 17, 2006
#11
  • May 17, 2006
  • #11
With a close ratio Toploader you need 3.70-to 4.10 gears out back. Your first gear is 2.32. Wide ratio Toploaders have a better 2.78 1st.
dennis112
1,561
36
79
May 17, 2006
#12
  • May 17, 2006
  • #12
RModel65---Good Advice Above!
If your car is primarily a street vehicle and does a little highway traveling, I recommend staying closer to the 3.70-3:80 range with your close ratio.
For those owners with a wide ratio, 3:25-3:50's work well and 3:50's are preferred for a performance street car.
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
L
Engine 97 mustang gt manual weird idol when off the throttle and coasting in 3rd, 4th, or 5th
  • Lanezs
  • Jun 9, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
