Toploader vs. T5 position with aerostar drivesaft?
  • Thread starter Thread starter downpiped
  • Start date Start date Oct 13, 2007
downpiped
36
Albany, Ga
Oct 13, 2007
  • Oct 13, 2007
I just finished swapping in my Versailles and now Im onto getting my aerostar drive
shaft measured and cut to the correct length. Currently I have a 4 spd top loader
and since my rear is geared to 3.50 , in the not so distant future I would like to put in a T5. Is there a significant difference in the position of the toploader and the T5, anything that would place more error on the measurement of the aerostar shaft?
downpiped
36
Albany, Ga
Oct 14, 2007
  • Oct 14, 2007
Ok...would the tailshaft of the toploader be the same length has the T5 or is it longer/shorter. Im trying to get a measurement for my driveshaft?
chepsk8
2,203
Easton, PA
Oct 15, 2007
  • Oct 15, 2007
When I did the AOD swap, I was told 1" shorter than stock.
downpiped
36
Albany, Ga
Oct 20, 2007
  • Oct 20, 2007
What are the measurements for the T5 and also the toploader? What about the bellhousing adapter, that would lengthen the postion?
skywalker
733
Pensacola, FL
Oct 21, 2007
  • Oct 21, 2007
the overall length of the T-5 is longer due to the input shaft. When I did my C-4 -> T-5 on my '68 i shortened by 3/4" and it fit perfectly. I've heard 1/2" up to 1". But I just looked at the situation with my drive shaft as it fit (or rather, didn't fit) to the T-5.
M
mikethebike
358
Greenville, SC
Oct 22, 2007
  • Oct 22, 2007
They had to cut my shaft when I intalled th t-5. If you go t-5 get the bell-housing for the t-5. You will not need the adapter plate plus you can go cable or hydraulic much easier.
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
M
  • mnky99
  • Sep 5, 2025
mnky99
M
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
So confirming what I need to do to put a '88 CV 302/AOD in my '65 A-code.
  • 1320stang
  • Apr 19, 2023
2K
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2023
1320stang
