Tork Tech numbers/pics/vids
  • Thread starter Thread starter bakos24
  • Start date Start date Jul 1, 2009
  • 3
First Prev 3 of 3
R
REDSTALION
15
#41
  • Jul 11, 2009
  • #41
Congrats man, very nice numbers & ride
I just cant wait for my kit to arrive, it should ship on 15th July.
bakos24
I find there is nothing better than a tasty wiener
87
134
NE, OH
Jul 17, 2009
#42
  • Jul 17, 2009
  • #42
Thanks guys
An update for ya.. Been seeing some fresh colorful greenish stuff on the garage floor - anti-freeze Not a huge amount but defiantly just started happening.
Also, whenever I start my car, there is a chirping sound coming from the front. Sounds like a TOB but it does not go away when I press the clutch in. It's pretty consistent and gets quieter as I come to a stop. when I do stop, the noise stops. It does completely go away after a while though. I was thinking possibly the belt
Other than that, still tearing up the asphalt
squeak93
2,351
417
164
Joplin, Missouri
Jul 17, 2009
#43
  • Jul 17, 2009
  • #43
Could be an idler pulley as well.
Doesn't the blower move a few coolant hoses around. Might want to double check all your hose clamps and such before a little leak equals a bad day.....
CobraRed_96_GT
1,421
UCSD/La Jolla
Jul 17, 2009
#44
  • Jul 17, 2009
  • #44
bakos24 said:
http://forums.stangnet.com/7557374-post12.html
Here you can see all the optional parts on a KB that come standard with the Tork Tech kit. Thanks to Gearbanger
TVS numbers a bit out of date tho, more expensive now.
LaserSVT
3,548
233
Jul 17, 2009
#45
  • Jul 17, 2009
  • #45
They may have slightly overfilled the system and its overflow but I would check the new couplers and pipes around the blowers snout.
The fact that the kit does not have a plug at the high point to burp it is a bit troubling to me too. On my 4Vs that plug was mandatory to properly fill the system. I guess if you parked yours at a nose up angle that would help but I digress...
The noise you are hearing is either belt slippage due to a weak tensioner (very common) or an idler going out. Need to rev it and listen. If it makes the noise at idle then most likely its an idler and if you take a long screw driver and place its tip against each center bolt on each idler and place your ear on the end of the handle you should be able to hear which one it is.
Good excuse to get a Billet Flow idler setup
Also just for safeties sake check the oil and make sure the coolant leak isn't from a blown head gasket.
EPIK
796
LEFT COAST
Jul 17, 2009
#46
  • Jul 17, 2009
  • #46
Sorry I didnt reply to this thread earlier... Congrats on the install... Looks great under that new hood, & the drop looks good too...
One question though, why did you remove the radio?
bakos24
87
134
NE, OH
Jul 18, 2009
#47
  • Jul 18, 2009
  • #47
Cool, thanks guys, I will have to check those out
Thanks Epik, reason I took out the radio was....well........just something different. I never had my radio on anyways when I was in the stang so figured it would be a good spot for some gauges
BlownStangGT
REPEAT
3,860
Lancaster, PA
Jul 18, 2009
#48
  • Jul 18, 2009
  • #48
Heck....keep the 4.10's and put a 6 speed in it
Flghtmstr1
572
Springfield, PA
Jul 18, 2009
#49
  • Jul 18, 2009
  • #49
My idlers squeak a bit too; just started happening when the weather got warm. As for the coolant, do you have the new aluminum / stainless reservoir, or the old black plastic one?
bakos24
87
134
NE, OH
Jul 18, 2009
#50
  • Jul 18, 2009
  • #50
I have the aluminum one
Flghtmstr1
572
Springfield, PA
Jul 20, 2009
#51
  • Jul 20, 2009
  • #51
O ok. The plastic one has a hole in the "cap", and coolant will sometimes bubble out of there when I shut the car off due to the momentum of the coolant flowing into the tank.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jul 20, 2009
#52
  • Jul 20, 2009
  • #52
bakos24 said:
Thanks guys
That's the main reason why I ran Premium Gold coolant through my blower and green through my engine. That way, when you've got a leak, you know which of the two its coming from. The squeek tells me its coming from the front somewhere and getting on the serpentine belt. It turned out to be the water pump on my Explorer the last time I had that happen...but its kind of an apples and oranges comparison.
I also forgot to add in the cost of the need for a new hood when going to the 2.6L Twin Screw update for the KB (since it won't clear the stock hood either)....so take that for what its worth.
Maybe you could use the extened hood scoop Tork Tech sells with the KB 2.6L.....if you've got any money left over afterwards that is?
  • 3
First Prev 3 of 3
M
Progress Thread Monkeybutt2000's 89 vert build thread- 408w build in progress
  • Monkeybutt2000
  • Apr 4, 2020
  • 20 21 22
73K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 20, 2026
2Blue2
July SOTM Winner!! bakos!!!
  • LaserSVT
  • Jul 17, 2009
1996 - 2004 SN95 Mustang -General/Talk- Jul 22, 2009
LaserSVT
had the stang buffed(pics & vid)
  • 98COBRA281
  • Nov 26, 2009
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 30, 2009
jomull55
J
Tork Tech Kit finally came
  • bakos24
  • Jun 5, 2009
  • 2 3 4
6K
1996 - 2004 SN95 Mustang -General/Talk- Jul 1, 2009
BlownStangGT
1200 Hours; No, It's Not A Kit; And Yes I'm The Owner. And A Can Of Bars Leak.
  • CarMichael Angelo
  • Jul 22, 2012
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 26, 2012
StreetsideStig
