stonegod85 said:
.just gonna rebuild mine and get an edge racing converter.
Edge converters are junk, end of story!....as are TCI converters! PI makes a good converter, but only their triple disk designs are really worth mentioning and you're gonna start spending some big money if that's the case.
Dark Knight GT said:
Here we go again........
:: buckles seat belt for the torque converter debate ride ::
I'm only going to point out one thing. While many people bash the Edge Racing torque converters, it is interesting to note that none of the people who bash them own one, or as far as I know, have ever owned one.
Perhaps the reason for this is that these people did the converter research necessary and know better that to bother with them.
I understand that the Edge Racing torque converters for the 4r70w uses a "smaller than stock lock up clutch piston", however, that same pistons in found in many other converter assemblies without problem. Remember, the size doesn't always matter, but it is the efficiency rating that matters. If size mattered, then people would be running 16in torque converters with 7 friction plates, yet they don't.
It's not only the size of the clutch they use, that makes them an inferior converter. They also cut a lot of other corners like using hollow rivets to fasten the turbine together, as well as drastically bending the pump fins and cutting the stator in order to control stall speed. Yeah, it may get the job done as far as increasing stall speed is concerned, but the byproduct of this is superheating the transmission fluid which makes the converter work much less efficiently than it was designed to.
Click on the link I posted at the bottom of this thread and it will explain to you a lot of the so called “tricks of the trade” that some of these companies like Edge do and you’ll second guess them as well.
TGJ said:
Buy your TC from someone who knows what they are talking about. Those guys sound like ass clowns.
I would contact Chris @
http://www.circledspecialties.com/ and talk to them.
Agree. I just got mine in from them yesterday, as a matter of fact. Chris is a super nice guy to deal with and the price wasn't too bad either. I also happen to know he does a lot of consulting with "Dirty Dog" one of the well respected converter guru's over at TCCOA, who also
really knows his stuff.
Mine is based off of an 11 1/4” modified Marauder T/C, which is already furnace brazed, then treated to a steel bearing conversion, solid rivets, Kevlar disk clutch, billet front cover, etc, etc…..and it retains full lock up capability! Everything the stock converter should have been. The stall speed he quoted me for this converter was in the 2,800-3,000rpm range, but since I'm running a Roots blower, I didn't feel as though any higher stall would be necessary. I’m sure he could have increased the stall speed further if I wanted him to. If you decide to go with him, tell him that you were refered to by "Brian from Canada". He'll know who you're talking about and may cut you a bit of a break on the price.
Here’s a good link posted by “Dirty Dog” from TCCOA which contains a lot of converter info that some of you may find interesting.
http://forums.tccoa.com/showthread.php?t=47149&highlight=inside+a+marauder+torque+converter
