  • 2.3L (N/A & Turbo) Tech
Torque Converter Lock-up Switch?
  • Thread starter Thread starter NicD
  • Start date Start date May 24, 2006
N
NicD
57
  • May 24, 2006
I recently bought a '88 2.3 auto coupe...Started another thread about it cutting off when put in gear...Idles fine in neutral and park...Checked for vaccum leaks with no luck...
I spoke to my boy's mechanic, he said he thinks its the "torque converter lock-up switch." Being that the only 5.0's I've owned have be T-5's and this is my first 2.3 and automatic, I have no idea what he's talking about...
Can anybody school me as to the function and replacement of this switch?
bhuff30
6,037
35
129
Olathe KS
May 24, 2006
  • May 24, 2006
There is no switch per say. The computer controls the converter lock up based on rpms, load, ect. Then, it grounds a certain wire leading to the tranny to lock the converter up. In my experience, even with that wire grounded, the converter won't actaully lock up unless you are moving at least 40mph because of a mechanical/hydralic lock out inside the transmission.
So I'd say no, this switch isn't the problem. I did have a torque converter lock up on me once... but that was with nearly 3x the power and torque output of a base 2.3.
You might learn something by jacking up the back tires, and putting it in gear. I would suspect a sensor on the engine to be the cause though.
N
NicD
57
  • May 24, 2006
So when the computer sends the signal to lock up the converter to increase efficiency, what mechanism is it sending it to - some sort of relay or "switch"?
It makes sense that the computer and mechanism would engage around 40 mph, because the car acts as if it were a 5 speed being started in 4th gear...
Maybe the mechanism being sent the signal to lock the converter isn't getting the message to disengage?
bhuff30
6,037
35
129
Olathe KS
May 24, 2006
  • May 24, 2006
The computer activates a solenoid. I beleive the solenoid cuts off fluid flow to a certain part of the converter, which forces it to lock up. I think you should verify that the torque converter is locked up, by doing some sort of test to see if it is locked. You could even put it in drive, let it die and then try turning the crank by hand.
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
1989 Passenger side electric window issue
  • Sanchez_005150
  • Jul 17, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 4, 2025
WillWho?
W
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
F
Resolved Stumble issue upon acceleration (1987 GT)
  • FoxDude87
  • Sep 16, 2024
  • 2 3
3K
Fox 5.0 Mustang Tech Dec 3, 2024
FastDriver
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
